  • SVT Tech Forum
Need help with lowering
  • Thread starter Thread starter xlr857
  • Start date Start date Jan 11, 2004
xlr857
18
  • Jan 11, 2004
I need a little advice on lowering a 98 Cobra. Im going with Eibach springs but I cant decide between the prokit and sportline. I like the lower look of the sportline but everyone has told me it is to low and to rough riding. Also is Caster / Camber plates a must on this. Ive seen pics of both kits but neither really seems like that significant of a drop. Any help appreciated.
C
chrisbudl1
436
springfield MO
Jan 11, 2004
  • Jan 11, 2004
I am having to make the same decision. I was told that I shouldn't need to get the c.c plates unless I go more than 2 inches. I am thinking of going with the sportline, and 18 in saleen wheels. I just put on a set of pro kit springs, with tokico blues, on my 94 t-bird. I know the entire setup is different, but the ride quality was better with the new stuff. Hope this helps. chris
Steel City
46
  • Jan 11, 2004
I had sportlines (2") on my 98. Simple install and looked great! As far as the c/c plates, throw on the springs, get it aligned and go from there. I put c/c plates on every stang I lowered, every time I went for alignment the tech told me he got it as close to spec as possible. Im not saying they are useless but I don't think you need them. Maybe if you were road racing and have some crazy setup or running coilovers, other than that I say last resort.
H
hotrodman
90
Boston ,Mass
Jan 11, 2004
  • Jan 11, 2004
i got the pro kit on my 99cobra with 18in.cobra r wheels with 275/35/18/ and it looks a little high.but can live with it im just going to go with a taller tire next time.40 series.i got the offset rack bushings.also.
xlr857
18
  • Jan 12, 2004
Thanks for the help. Im going with the sportlines if I dont get the camber kit I should be alright I'm assuming. Do any of you have excessive tire wear except for the obvious bald rear tires.
C
chrisbudl1
436
springfield MO
Jan 12, 2004
  • Jan 12, 2004
if you mean from running on the different suspension, no. If you get it aligned you shouldn't have any excess wear. It is only if you go any lower you will need to get the plates, because the factory equipment wasn't made to correct such a change in ride height. If you don't get it aligned, the tires wont last to long.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • SVT Tech Forum
