Need help with "p" motor swap
I've swapped a 97 explorer motor in my 95 gt. i have put everything new on it and cannot get it to start. Ive put a coil, stator, ign. module, cap, rotor, wires, plugs, even a new timing chain, and it wont start. i know the timing is correct, and it is getting fuel. Im wondering if going from a crank trigger to a distributor is the reason. thanks to any help.
that i think would be your prob. you wound need to swap out the OBD II puter and harness from the exploder or convert the newer motor back to the OBD I harness. I don't know for sure maybe someone else has done this before and can chime in
