Need help with Revving motor
  • Thread starter Thread starter ndalake
  • Start date Start date Dec 30, 2006
N
ndalake
Goodview, VA
Dec 30, 2006
  • Dec 30, 2006
Hello, I need some help. I have a '89 GT with a 5 spd, AC, runs really good most of the time with normal rpm's under idle at about 800 - 1000 rpm's, then after about 45 minutes of driving, the car will idle up to about 2000 rpm's and hold there. It doesn't go up anymore and doesn't come back down either. Once it begins to rev high, you can turn the car off and start it right back and it goes right back to 2000 rpm's again. It's really annoying at a red light with flowmasters! The check engine light does come on randomly, just about everyday after about 20 minutes of driving. Is this a MAF problem, a ECU problem or something else? Is the check engine light connected to this issue? When I purchased the car used in September, it didn't do this. It has developed this issue over the last couple of weeks.
Does anyone else experience this?
Thanks for any help you can provide.
HISSIN50
34
129
Dec 30, 2006
  • Dec 30, 2006
You answered your own question - grab them codes and take a little guesswork out of it. Jrichker has a couple of sites that go into pulling codes if needed.
Good luck.
R
robertdale
382
kentucky
Dec 31, 2006
  • Dec 31, 2006
I had the same problem with a bad Throttle position sensor. Might want to pull codes and check TPS voltage.
txstang84
1,639
42
69
Tuscola, tx
Dec 31, 2006
  • Dec 31, 2006
ck the IAC too...
superhuaman
907
Harrisburg, PA
Dec 31, 2006
  • Dec 31, 2006
+1 for the iac. if the tps causes a high idle, it will not return instantly upon restart.
HISSIN50
34
129
Dec 31, 2006
  • Dec 31, 2006
If you stop some place safe when it decides to idle up, you could disconnect the IAC electrical connector and see if the idle drops. If it does, that would be telling.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 31, 2006
  • Dec 31, 2006
You guys with idle problems could same a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first post has all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
Your problem is covered in the sticky. Check it out.
87ttopstang
342
Ontario, Canada
Jan 1, 2007
  • Jan 1, 2007
I had the exact same problem a few years ago. Put on a new IAC and it fixed the problem.
N
ndalake
Goodview, VA
Jan 2, 2007
  • Jan 2, 2007
Thank you all so much for your insight and help. I thought the company where I work had a lot of acronym's, they've got nothing on this group. I tried to find info about this prior to posting and had no luck. I'm going to go read this info and get educated before I ask anymore stupid questions.
Thanks a bunch.
ndalake
seijirou
2,417
DFW
Jan 2, 2007
#10
  • Jan 2, 2007
  • #10
Thanks a bunch.
ndalake
Not a stupid question chief, nobody popped out knowing this stuff. Sometimes you need to ask some questions to see how much there is to learn.
The IAC is the Idle Air Control valve. It's the cylinder that's bolted to the side of your throttle body. When it's open, air can go around the throttle body blade. The computer uses it to control the idle rpm.
The TPS is your Throttle Position Sensor. Which is just as it sounds, it lets the computer know what position the throttle is in. Be it opened or closed or somewhere inbetween.
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Nov 14, 2026
Fox 5.0 Mustang Tech Nov 15, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
