need help with testing compression
PeteyAce
346
I got a tester and wanna test my compression. Ive read that i gotta have opitimum temperature, and i also read that i have to take off the air filter and have the tb linkage open?:shrug: i dont want an exact reading, i just want to see if compression is well enough so i can do work to the motor. How do i set this up? And what range should i be looking for? 140psi? I just wanna go for a normal h/c/i with blower in possible future, with a rebuilt top end.
I don't believe you need to remove the air filter, but you will want to prop the throttle blade open. IIRC, you should be looking for 120+ PSI from each cylinder, with no more than 10% difference between them. If one tests abnormally low, squirt some oil into that cylinder and repeat the test to see if the rings or bores are worn. The oil will increase compression in that instance (wet test), and will differentiate between something such as a bad valve seal, since it won't help in that case.
yeah you can just mash the throttle. and yes unplug the coil and cut off the fuel pump. be careful with the coil though, it'll still arc if you have anything near it. mine starting arcing on my 4g alt wire when i ran comp test.
I agree. Disable the control side of the ignition.
Put a battery charger on the battery so you have consistant cranking the entire time. I always do a dry and then wet test for each cylinder.
Good luck.
i was only able to do 2 cylinders, it got too dark and cold. But i got a quick question. Friend of mine was supposed to help me, he didn't show but i was telling him that when i would crank the car and check the car the compression on the gauge, the compression would slowly fall (after i stopped cranking). For one of the cylinders it read 175psi went down to 150psi in about a minute for example. He said that could be me losing compression through the rings or through scratches on the walls. If that is true, then if i do a wet test and if the pressure holds on the gauge then i guess time for a rebuild?
You need to do a leakdown test to infer seepage like that IMHO.
Also, we should have noted if we didnt that the most reliable results come with a hot motor (more true with forged slugs than hypers).
The cylinders are not air tight, the compression and oil rings have gaps, so it won't hold any psi just sitting still, so I am not sure exactly what you are talking about. Your gauge should hold the highest psi that it received, if it doesn't, then it is a faulty gauge or it is not meant to hold a psi. The compression results should be achieved during cranking, not when you stop.
ok results are in, i was actually surprised, cars got 140xxx, engine is dropped i was told it has anywhere from 10-20k less on it when i got the car. I put nothing but highway when i got the car which was around 110xxx, and never beat on it. oil every 3k blah blah you get the point.
FW
1 5
2 6
3 7
4 8
1. 184
2. 183
3. 185
4. 182
5. 185
6. 182
7. 185
8. 181
Average is 183
those numbers look perfect. what made you want to run a comp test? and yeah, for what you were saying about the losing compression, that's going to call for a leak down test. just cause your compression numbers came back good, doesn't necessarily mean the leak down will too. just forewarning you.
the engine has a few miles on it and i wanted to see how it was, what i was actually talking about before was nothing, the tester was losing compression alot just exactly what fast63 explained. I will do a leak down test when i get a chnace it a warmer day with less wind.
Yeah, those compression numbers look very good indeed. a LOT too! My 85 only gave me 110psi all around, but when I looked it up in the book, that's what it was supposed to have. Even with 10:1 compression now and the stock cam I only get 135:shrug:
i find it odd though, i mean i have a completey stock motor out of at least at 89+, its dropped in, its a dropped motor, i dont know what the previous owner did to it. could of rebuilt or treated like crap. ill know after a wet test but it was too windy out today.
hey cenok, by wet test do you me a leak down? Aren't they 2 different test?
A wet compression is like the dry comp test you already did, except that you add a dab of oil down the plug hole before beginning. This helps the ring seal.
A leakdown test is entirely different.
Alright wet done, i dont think the results are too good. The 7 8 where done when the motor was alot cool sitting for about an hour or so in 35 degree weather. and cylinder 2 had not changed at all but after i finshed everything i tested it again and got lower results (tested it 3 times, did a dry before the wet, so ones with 2 dry results where yesterdays and todays and with one the same as prior). Sorry by the way cenok, i read wrong.
FW
1 5
2 6
3 7
4 8
cylinder - pressure dry - pressure wet
1. ---------- 184 ------------- 190
2. ---------- 183/176 ------- 183/183
3. ---------- 185 ------------- 200
4. ---------- 182 ------------- 195
5. ---------- 182 ------------- 194
6. ---------- 182 ------------- 205/200
7. ---------- 185 ------------- 200
8. ---------- 181/177 ------- 185
