need help with testing compression
  • Thread starter Thread starter PeteyAce
  • Start date Start date Dec 1, 2007
First Prev 2 of 2
PeteyAce
346
Dec 5, 2007
#21
  • Dec 5, 2007
  • #21
even though they jumped so much from dry to wet?
Fast63
717
#22
  • Dec 5, 2007
  • #22
IMO, doing a wet test is not accurate. Your numbers still look just fine. Wet tests are usually for when you have abnormally low compression in a cylinder and you want to test the rings by adding oil in the cylinder. If the compression goes up a lot, then you know the rings are bad. But in your case, all your dry numbers are fine. Wet tests just are not consistent enough. Besides, who drives around with excess oil in their cylinders all the time? Go by the dry numbers.
HISSIN50
34
129
Dec 5, 2007
#23
  • Dec 5, 2007
  • #23
Fast's reply was a good one.
The numbers didnt jump much at all. You can see some big spreads when ring-seal takes a dump.
As a matter of routine, I do dry and wet tests (it takes but a couple extra minutes to do the second test) and log the info for future reference.
PeteyAce
346
Dec 5, 2007
#24
  • Dec 5, 2007
  • #24
thanks for all the help.
First Prev 2 of 2
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
ECU help!
  • starkiller1134
  • Aug 16, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
