Need help with this crazy motor...
68converted
772
Colorado
I know that I have been asking a ton of questions of you guys/gals, but I am so close and I need to ask one more question. The last question I posted I thought that I may have actually installed the cam 180* off of TDC, thinking I set it on the exhaust stroke rather than the compression.
A buddy of mine helped me test the pressure build up of the #1 cyl. and after all that stress. I built it correctly after all. What I did determin is that I had the distributor stabbed so that #1 fired after the cyl. was on its way down, so I was getting very poor combustion. I restabbed at a point at 4* BTDC, and then checked the timing with the gun after it fired right up. It read 10* BTDC.
The problem is that the headers immediately started turning red hot. (like in less than a minute???) I quickly shut the motor off and there was also a bunch of smoke (or steam???) came billowing out from around the back area of the intake.
The idle was reasonable at 900 rpms. Any ideas????
The steam may be water leaking from the intake manifold and squirting out on the header pipe. The last bolt on the rear of the lower intake manifold is next to the water passage for the cylinder head.
Check to see that you don't have a leaking valve cover gasket dumping oil on the header or the PCV valve disconnected and pointing at the header.
Instant red hot headers - possible lean mixture...
Check for presence of vacuum leaks by using a vacuum gauge. You should see 18"-21" of vacuum at 1000 RPM. Less than 16" would make me think vacuum leak. The PCV valve not installed correctly would also cause a vacuum leak.
Check fuel pressure – remove the cap from the Schrader valve behind the alternator and connect fuel pressure test gauge to Schrader valve. The fuel pressure regulator is located on the passenger side of the car behind the throttle body. Disconnect the small vacuum line from the fuel pressure regulator and plug the line. Leave the port where you removed the line uncapped and open to the atmosphere.
Start the car and observe the pressure: you should see 37-41 PSI at idle.
Be sure to unplug and reconnect the vacuum line to the fuel pressure regulator when you have finished your tests.
Fuel pressure test gauge are available for rent/loan at most major auto parts stores like AutoZone.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
You're headers turning red hot (especially so quickly) indicates that you probably still have a timing issue. The exhaust valves are open during the power stroke, and the combustion event is blowing into you're headers. This is also confirmed by the smoke coming from the intake, because the exhaust gases are being blown back through the intake on the exhaust stroke.
Awesome info. I thing that the timing is the issue. I really did not change anything but to restab the distributor. I may have just over done it. I will give it another shot and see how it does. I am thinking now the "smoke was radiator fluid burning off as I forgot to put a catch rag under the TB spacer before I pulled it to check the rockers for movement/TDC. Oops.
Additionally, some oil may have dripped out when I pulled the valve covers. I seriously hope that is what it was.
It may take a few days to get to the car, but I will post an update.
Thanks again for the info!!!
You will need a timing light to set the timing. There is no way to accurately set the timing without a timing light.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer
on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor
to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block,
(you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards
or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor,
but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't
align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too
far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car
runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back
in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
