need help with transmission problem
Rrich
184
my 94 t-5 tranny has a crack in it right under the drain plug for the tranny fluid. i am going to get a different tranny put in. will a 87-93 T-5 tranny fit in my car if i change the input shaft from my car and install it in the older tranny as well as use my bell housing?
I put a 93- tranny in my 95 stang during an AOD change over. I tried using a 5/8" DS spacer but it sucked. I took my DS to a shop and had a longer tube installed and balanced along with new u-joints (while it was out). Car is tight now with the longer DS and I did no changing in the tranny. Total cost with u joints was $134.00 in STL. Oh, the mount bracket is short too almost an inch too because the bellhousing is shorter on 87-93 t-5's. You will have to improvise a plate for the mount but that is easy.
Good luck
