Well I get the idiot of the year award doing my Vortech install..
Got everything done with the installation of my kit, took it out for a test drive and everything seems ok until I open the hood and see oil splattered everywhere!
I figured that the only explanation was that I didn't properly tighten down the oil feed fitting to the oil filter mount...since after all that was the only oil line modification that I did that would cause this.
So I proceed to tighten down the 1/4 NPT street tee and all of a sudden it snaps right off!...leaving a broken piece of the threads inside the oil filter mount!
Turns out it was never even that piece to begin with as I'm looking at my stupid mistake I see that the oil feed line has a slit on it and it was leaking from the tube itself. Now I have 2 BIG problems...getting a replacement oil feed line, and getting the dam threads out of my oil filter mount.
What do I do? I tried to get a reverse threaded drill bit in hopes of loosening the piece out, but it's a very tough angle to reach. Can I safely remove the oil filter mount from the engine without damaging anything?
Sorry for the long post, I have no help on this and I don't want to make something so simple get even worse than it has. Thanks!
