  • SN95 4.6L Mustang Tech
Need help with vortech issue
  • Thread starter Thread starter IXRsupercharged
  • Start date Start date Aug 10, 2005
I
IXRsupercharged
Banned
May 6, 2005
40
  • Aug 10, 2005
I have a vortech s trim @ 16 psi and I just added a paxton air to air intercooler. When I accelerate the car chokes and the blower surges. It happens when I let off the gas too. Is this because I need a Vortech mini race bypass valve? Thanks
2001sleeper
136
  • Aug 10, 2005
if you have a stock bypass, you really need to upgrade it. also check for any vacuum leaks. Did you get a new tune also?
I
IXRsupercharged
Banned
May 6, 2005
40
  • Aug 10, 2005
we can't tune the car because its choking
2000 blown conv
61
Ontario Canada
Aug 10, 2005
  • Aug 10, 2005
If you are running the stock bypass that comes with the kit,its only good till 10 psi at the most...I have the mini race bypass and it works great, I was not getting a surge but rather popping off my disharge tube when shutting down the boost,,and that was only at 10 psi..I did not have the problem you were having.
I
IXRsupercharged
Banned
May 6, 2005
40
  • Aug 10, 2005
what will happen if I don't upgrade the bypass valve?
2000 blown conv
61
Ontario Canada
Aug 10, 2005
  • Aug 10, 2005
For the money vs complications,,its worth the 250$..
I
IXRsupercharged
Banned
May 6, 2005
40
  • Aug 10, 2005
yea I know and I will get one but do you think this is causing my car to choke at part throttle?
2001sleeper
136
  • Aug 10, 2005
i you don't upgrade and you truly have compressor surge, you are in danger of destroying the blower. there are alternatives to a new bypass besides shelling out the big bucks on the vortech unit. you can run two valves, but it won't look as good.
what are the rest of your mods?
2001sleeper
136
  • Aug 10, 2005
at what rpm does it choke at, and by choke do you mean buck?
I
IXRsupercharged
Banned
May 6, 2005
40
#10
  • Aug 10, 2005
  • #10
The car idles fine and is ok at WOT but as soon you give it any throttle like 1200 to 1500 the car chokes and pops. sometimes you can get past the choke but other times it just pops
I
IXRsupercharged
Banned
May 6, 2005
40
#11
  • Aug 10, 2005
  • #11
It won't even move when it chokes
I
IXRsupercharged
Banned
May 6, 2005
40
#12
  • Aug 10, 2005
  • #12
it has a built block .20 over and stage 2 comp cams
I
IXRsupercharged
Banned
May 6, 2005
40
#13
  • Aug 10, 2005
  • #13
the MAF voltage is bouncing up and down
2001sleeper
136
#14
  • Aug 10, 2005
  • #14
what kind of MAF?
I
IXRsupercharged
Banned
May 6, 2005
40
#15
  • Aug 10, 2005
  • #15
90mm lightning
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
