  • SN95 4.6L Mustang Tech
need help with whining noise
  • Thread starter Thread starter undefeat89
  • Start date Start date Sep 10, 2009
U
undefeat89
michigan
Sep 10, 2009
  • Sep 10, 2009
hey i have a 1999 mustang gt and when im driving on the freeway my car makes a humming/whistling noise. it appears to be by the rear passenger area and it only starts at around 58 mph and stops at 65 mph. sound only happens when i press the accelerator and it stops when i let off. again it only occurs between those two speeds it seems like.
T
tonytaylor85
126
Augusta GA
Sep 10, 2009
  • Sep 10, 2009
Gear whine would be my guess. Does it have aftermarket gears?
It could also be bearings but I have never heard of bearing problems with the 8.8's and gears are more probable.
U
undefeat89
michigan
Sep 10, 2009
  • Sep 10, 2009
is that an expensive fix
U
undefeat89
michigan
Sep 10, 2009
  • Sep 10, 2009
yes they are stock.
T
tonytaylor85
126
Augusta GA
Sep 10, 2009
  • Sep 10, 2009
usually. Does it have aftermarket gears? If you don't know tell me what RPMs you turn in 5th gear (or overdrive) at 70 MPH. To completely rebuild the rear end it would break down something like this:
All from memory but should be close
new gears: $200
new bearings: $150
new trak-lok clutches: $60 for stock replacement $115 for carbon fiber cobra setup
new fluid: $25
XL3 friction modifier: $16
Labor took me 10 hours and I had a grease pit and a press and bearing pullers and separators and air tools. A shop will charge 7 hours labor I am guessing. I'm not sure what labor runs in your area but around here it's $80/hr.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Sep 10, 2009
  • Sep 10, 2009
Could also be an axle bearing too.The thing with the rear diff,it's hard to narrow an issue down since the noise(s) travel threw the diff,or the driveshaft.
1987stangman
684
24
  • Sep 10, 2009
That's for sure. I have a 96' GT with rear whine ALL the time. Has stock 3:27 gears (convertible) and having built several 8.8's in Mustangs I would save my money or collect parts to rebuild the diif and axle at the same time to be safe. It's hard to narrow a noise in their rear.
U
undefeat89
michigan
Sep 10, 2009
  • Sep 10, 2009
is it safe to drive with that little whine with between those mph?? could it get worse?
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Sep 11, 2009
  • Sep 11, 2009
It will eventually get worse.
R
1999 mustang gt whining noise
  • Rlee4252
  • Jul 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Mustang5L5
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
