  • 1994 - 1995 Specific Tech
Need Help!!!!!
  • Thread starter Thread starter stang723
  • Start date Start date Dec 27, 2003
stang723
163
houston, texas
Dec 27, 2003
  • Dec 27, 2003
I have two problems..............1) This one happened first; the light in the inside of my car, on the roof, wont go out, even with both doors closed, trunk closed, etc. So does anyone know how to get this light to turn off? 2) Because the light was turned on i thought that something was blocking the door latch or something, so i accidentaly forced the latch in the door down, and i cant get it back up, so my right door wont close (I am such a genius). I would really appreciate some help or advice, cuz my usual mechanic isnt open until monday, because of christmas break.. thanks.
baglock1
The Bartender
6,612
Space Coast, FL
Dec 27, 2003
  • Dec 27, 2003
2nd problem first. Look at the door latch mechanism and stick a screwdriver in through the side (in behind the latch hook). Open the door handle and pull out on the screwdriver (towards the driver's side, not the rear of the car). The screwdriver should act like the door pin and pull the latch out as if the door is being opened. That should do it. Next, don't do that again.
1st problem: I'd suspect one of the door switches (in the door jam towards the front of the car) is bad. First push in in and out a bunch of times just in case it's stuck (not likely though). Next, pull them out and test them with a voltmeter. Replace if necessary.
On edit: I forgot to ask the obvious. You did make sure the interior light wasn't manually turned on, right?
stang723
163
houston, texas
Dec 27, 2003
  • Dec 27, 2003
Well I got the door unlatched, and i tried what you said about pushing the door switches in and out, and the light didnt go off, so does this mean that i need to replace them? Should i just go to a ford dealer and ask for them?
baglock1
The Bartender
6,612
Space Coast, FL
Dec 27, 2003
  • Dec 27, 2003
Not knowing how electrical savvy you are, if it was me, I'd first remove them and test them to make sure that it is indeed the switches that are bad. They are a normally open switch (closed when the door is open). And yes, the dealer should carry them (or maybe even the local parts store).
Until then, I'd pull the bulb just to make sure the battery doesn't drain though.
5.0 from 95
738
Emory, TX
Dec 27, 2003
  • Dec 27, 2003
Mine were the door switches. Once I replaced them, which I got from the Ford house, no more lights on going down the road.
Paul
Need help 94 GT convertible top leaking
  • Scott94gtvert
  • Aug 9, 2025
1994 - 1995 Specific Tech Aug 9, 2025
General karthief
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
