Need Help
  • Thread starter Thread starter new46stang
  • Start date Start date Jul 12, 2007
N
new46stang
146
AZ
Jul 12, 2007
  • Jul 12, 2007
I was wondering if anyone has had a similar issue and what the fix was. Unfortunately, I am thinking the worst. The car is a 91LX 5.0 AOD 162k on the clock, the car is stock. All of a sudden I have developed a vibration at idle. It gets really bad as soon as you start to roll (0-5mph). The faster I drive (normal speed limits), the vibration settles down. I have not had time to pull codes yet. I have checked for vaccum leaks and spark at all cylinders, looks ok. The motor really isn't jumping around that bad but my battery, overflow tank and steering wheel shake really bad. It's not driveline (drive shaft, rearend) cause it happens when the car is not moving. I am thinking something with the transmission - torque converter. Anyone have any other ideas or methods to eliminate things? Any input would be appreciated!
Thanks,
Matt
88mouse
630
Mooresville nc
Jul 12, 2007
  • Jul 12, 2007
Sounds like a harmonic balancer to me. Check that first there bad about coming apart.
N
new46stang
146
AZ
Jul 12, 2007
  • Jul 12, 2007
Right, I know about those cruddy things. It has had a slight "wobble" if you could call it that. I don't think it has gotten any worse since this new vibration started.
Thanks,
Matt
88mouse
630
Mooresville nc
Jul 12, 2007
  • Jul 12, 2007
It don't take much tho if its wobbling i would change it. Could end up messing up the main bearings.
4G-KDMP
935
CA
Jul 12, 2007
  • Jul 12, 2007
that was my exact same thought.
88mouse
630
Mooresville nc
Jul 14, 2007
  • Jul 14, 2007
Just got done puting my motor in my notch and the balancer had spun and i drove it up the road and broke a crank.
93 LX
3,081
Norwalk, CA.
Jul 15, 2007
  • Jul 15, 2007
well check your timing if its way off then the balencer ring spun.
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
