NEED HELP!!!
MACH_WON04
18
So im still having probs with the tranny in my mach. Everytime im rolling and in gear, once i hit about 2000rpms, a noise from the bottom that sounds like a long squeak comes out. it sounds like metal on metal. also the clutch rattles like a mexican jumping bean and at idle a constant noise sounding like metal on metal is let out as well. Im thinking that i might need to adjust the clutch cable....so does anyone know if any special tools are needed or a link that can help me out? oh and as an fyi i just replaced the throw out bearing
Throw out bearing is probably making the noise you hear. Try spraying a little lithium grease on it. Also check you fluid level in the tranny while you are under there.
If you have the stock clutch cable lift with your tow then depress the pedal. You should hear a click as the quadrant adjusts. If that doesn't help you might need to get a firewall adjuster.
