Ok so i finally got 42lb injectors and a pro m 80mm maf,did have 30lbers with FMU and 255 pump, having some issues, If im driving along in 5th gear or anygear and leave offf the throttle for a while the car sputters and then clears out wen i rev it, also if it shuts off I have to floor it to restart it, I have the fuel psi set at 42, and I left the FMU on because i dont have a recalibrated disc for it ,i did remove it and boosted the fuel press to 60 and it didnt run nearly as strong and it was leaning out so i didnt get on it too much It feels like i gained hp at higher rpm tho leaving the fmu and 42psi, any help with the fuel pressure? and I keep reading to remove the FMU but im scared to lean it out and it doesnt run as good. what would be best, Do I just need a tune or what?
