need help!!!!!!!
02pinkstang
Ok so I need a little help here. I went to the store and when I came out my car wouldn't start. All the power in the car worked like radio, lights, ect. But when I would go to start it there was no noise. I then had the solenoid hot wired to a push button and it started. I then replaced the battery, ignition switch, and the neutral safety switch and its still doing the same thing. I have a 2002 automatic v6 mustang. Any help would be much appreciated. Thank you.
If you try and crank it over and there is no noise... Hmmm. This happened to my Dodge ram once. There was an in-line fuse going from the battery to the starter that was blown. I replaced it and it fired right up. Past that, there might be a bad starter issue. Schucks or napa might be able to test it out if you can drive it there.
