NEED HELP
Busa1300
14
Heys i just bought a 99Gt and it is a 5 speed. I noticed the other day while sitting in the drive way. That when it is running i can hear a kind of knocking coming from the transmission. It is like something is running or something. And when i press the clutch just a little bit the noise stops. I can let off the clutch and it does it again. I do not know much about 5 speeds. Can anybody help me out with my problem?
ok man thanks. i will do a little more research on which parts to buy. And how to replace them. The bad things is i bought the car two weeks ago and i have the paperwork showing that the transmission was rebuilt in Feb. I would of thought they replaced the throw out bearing and clutch. But i guess not. Well thanks again
Not sure where you live, but if the car was not bought "as is" there may be some recourse through some type of "lemon" law.
Aside from what you are describing, it sounds like chatter. Could be bearings (as suggested) could also be a worn out clutch plate.
Good luck :nice:
I don't agree with the TB theory.
I suspect what you're hearing is normal gear noise. When the engine is turning and the trans is in neutral there's still a bunch of cogs and junk turning in the gear case. Minute changes in engine speed at idle can cause the gears to knock back and forth a bit in their backlash and you hear this as a sound from the gear box. It can be exacerbated if the car has a lightweight flywheel or cams and the idle is rougher than OE. (You should hear a VW O2J 5-speed transaxle with a light flywheel...)
A bad TB is characterized by lots of noise -- squeal, groan, screech etc -- and perhaps "grumbling" felt when you press on the clutch pedal. But the bearing is doing pretty much nothing and under zero load when the pedal is released.
ok well i guess i just need to do a lot more research before i start tearing into it. But like i said all i have to do is lay my foot on the clutch pedal and the noise quits. So i know it cant be that big of a problem to fix. But i just am trying to figure out what to look for. Before i start changing a bunch of stuff i dont need to mess with
I agree.. Sometimes even an A/C compressor can introduce a vibration thru the crank into the trans and cause it to rattle/knock. Make sure it's full of good lube and keep an eye on it. Don't tear in to it yet. :nice:
Actually, I just re-read what you said in the OP after reading your reply and notice that you seem to be saying that this noise goes away even with just a little pressure on the pedal; that is, it doesn't have to be fully depressed. If this is the case then it's not "normal" gearbox noise you're hearing since the gear box is still connected to the crankshaft via the clutch.
You might have runout in the diaphram spring of the clutch that's causing the TB and release arm to move around a bit. Putting some pressure on the pedal puts a bit of preload on the spring, release bearing and the arm and quiets things down. Get under the car (jackstands, watch hot exhaust parts etc) while it's idling and eyeball the release arm. How much is it moving? Can you put your hand on it and feel the "knocking"?
