Need help
  • Thread starter Thread starter Amo3390
  • Start date Start date Mar 7, 2013
Amo3390
  • Mar 7, 2013
I have a 91 hatch converted to carburetor I'm going to be using stock pistons, stage. 1 trickflow cam 180 cc 58 cc aluminum heads roller rocker am I going to be good on clearance ?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 7, 2013
  • Mar 7, 2013
I assume you meant will you have sufficient piston to valve clearance? Who knows? what brand heads and what size valves. are the heads milled. what head gasket, what ratio rockers, what length pushrods.
Ask yourself this, do you want to find out you you don't have enough clearance by mocking it all up with the proper ptv tool and lifter, or do you want to slap it all together based on what someone tells you over the internet and pray your pistons don't smack your valves. It is not hard to check for proper PTV clearance. Do a search for it.
Amo3390
  • Mar 7, 2013
I have flow tek heads 1.94 intake 1.54 exhaust 1.6 rockers I still need to measure pushrod length I guess I was just curious if I could get away with my set up wih stock pistons
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
