Need ignition help
  • Thread starter Thread starter darthcual
  • Start date Start date Jun 16, 2005
darthcual
985
Arlington, TX
Jun 16, 2005
  • Jun 16, 2005
this morning my car tried to turn over and wouldnt and i took the key out it kept trying to turn over(had to run in the house and get my 1/2 inch to disconnect the battery to get it to stop. Is my ignition switch bad or is it the tumbler and key? Any help, thanks in advance.
HISSIN50
34
129
Jun 16, 2005
  • Jun 16, 2005
Probably a latched starter relay (solenoid).
When this happens, pull the slide-on wire off the solenoid (it is at 12 o'clock on the solenoid). If the car stops cranking, check that wire for having 12 volts with the key not in the crank position (I very much doubt this is the case).
Otherwise, if the starter keeps cranking with that wire disconnected, the solenoid is latching or you have other issues.
Good luck.
darthcual
985
Arlington, TX
Jun 16, 2005
  • Jun 16, 2005
So you think its a relay and not the ignition switch. I heard that these ignition switches go bad at about 100k miles. Where is that relay located. thanks.
HISSIN50
34
129
Jun 16, 2005
  • Jun 16, 2005
I gave info for you to test it - I think it is more likely to be the solenoid than the ignition switch, but with two minutes worth of testing you will know and not have to guess.
The ignition switches could go bad long before 100K - they were a recall item.
The solenoid is on the driver side fender, just in front of the strut tower.
Good luck.
darthcual
985
Arlington, TX
Jun 16, 2005
  • Jun 16, 2005
Thanx for youre help Hissin, always you are a wealth of information....*sings* Did you ever know that your my heroooo....
LOL
I'll let ya know how it turns out
Lates
darthcual
985
Arlington, TX
Jun 17, 2005
  • Jun 17, 2005
I know you like hearing it so...You were right, Hissin! it was my starter solenoid. Almost ran myself over but i got it fixed. Thanks
DC
HISSIN50
34
129
Jun 17, 2005
  • Jun 17, 2005
Congrats on getting it fixed.
And thanks for the compliments. Sometimes I post when irritated (not from this site or anyone on it - just me) and I come off as abrupt. That was not my intention (in re-reading what I posted before, I can see that the tone of my post was lackluster).
If one searches my posts, I almost always recommend having the car in neutral, ebrake on solid, feet clear of the car, etc. But I did not think of posting that this time; I am glad you said something, and now I have. It is good for future searchers.
Again, nice work!
darthcual
985
Arlington, TX
Jun 20, 2005
  • Jun 20, 2005
Hey abrubt or not i'm just happy someone is willing to help me. I appreciate it very much. Plus i get to learn something.
D
Deleted member 87397
Jun 20, 2005
  • Jun 20, 2005
yeah I hooked my starter solenoid up backwards once and it kept crankin on me when I went to shut it off. Glad you got it fixed.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
