Need info on '94-95 accessory brackets
  • Thread starter Thread starter 85_SS_302_Coupe
  • Start date Start date Apr 2, 2009
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 2, 2009
  • Apr 2, 2009
I was talking to a guy and he mentioned that the '94-95 accessory brackets moved the alt and power steering closer to the engine and gave you extra engine-to-radiator space. Is this true? If so then aside from the alt bracket, what do i do about the power steering bracket as far as A/C delete goes? Can i still use the delete kit i have or would it not line up? If not then is there a similar kit from Ford that i could use? I'm assuming the water pumps would be totally different then, correct? Also the crank pulley as well?
93 LX
3,081
Norwalk, CA.
Apr 2, 2009
  • Apr 2, 2009
yes all the pulleys sit closer to the block. You would need a front engine cover, water pump, alternator pulley (3g alt), smog delete and ac delete and ps for a 94-95 if it works at all.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
