I was talking to a guy and he mentioned that the '94-95 accessory brackets moved the alt and power steering closer to the engine and gave you extra engine-to-radiator space. Is this true? If so then aside from the alt bracket, what do i do about the power steering bracket as far as A/C delete goes? Can i still use the delete kit i have or would it not line up? If not then is there a similar kit from Ford that i could use? I'm assuming the water pumps would be totally different then, correct? Also the crank pulley as well?
