Need info on axle housings..
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
I have a set of 00 axles and caliper brackets a that I am want to trade for 94-98 stuff, since they are about 1.4 longer than fox body stuff. When I posted it, had a person reply that the 99+ axles housing is also longer than the 94-98's...If so, I didn't know that, and just want to verify if they are..
Yes, according to Matt90GT, the 99+ housings are longer also. Also, from what I understand, the brake brackets that mount the calipers to the housings on 94-04 cars are the same. So you can use the brake parts from a 99-04 on a Fox if you use the 94-98 axles.
The brake brackets that mount the calipers to the housings on 94-04 cars are the same. So you can use the brake parts from a 99-04 on a Fox if you use the 94-98 axles
Thanks trbkrb,, for info. Thats good to know, so basically all I need is axles then..I have everything else...
