need more clutch cable
any recent work on the car??? cables do stretch out over time and if you recently replaced the clutch then the cable will be longer than needed. time for a new one. MM probably has the best,
Are you sure you have the stock quadrant/pawl assembly? Is there an adjustment nut on the trans-end of the clutch cable (at the fork) or a firewall adjuster in the engine bay?
