If there's gas dripping into the carb, the floats are set too high or the needle/seats aren't sealing. Take a screw driver and reverse it in your hand and tap firmly on the needle adjuster screws with the handle. That will usually unstick the needle/seat or otherwise known as a stuck float. If that doesn't help, remove the sight plugs (right side of the bowls) and see if any fuel pours out, only a slight bit should seep out if the floats are adjusted correctly. Too much fuel pressure will also force the floats down and open the needle valves. It takes very little pressure and flow to feed a carb. I ran a low pressure/ 30 gal. per hour electric pump to feed a 400+hp 331 topped with 3 Holley 250 cfm carbs. Only time it was every insufficient was when the inline filter plugged between the tank and pump.
