Need Plug Recommendation for Nitrous
Auto Reverse
265
Buffalo, NY
I'm looking to run a 100 HP Zex dry kit on my DSS 331. I have the following mods. What's plugs P/N do you recommend and do you see any problems running nitrous with my setup? Thanks for the assistance guys.
DSS Pro Bullet 331 Short Block
AFR 165 Heads, 58cc
Crane PowerMax Cam (F-303 Specifications)
Holley SysteMax II Intake
C&L 76mm Mass Air
70mm Throttle Body
30 lbs. Injectors
MSD Digital 6 Ignition System
MAC Longtube Headers
MAC ProChamber H-Pipe
MAC ProDumps Exhaust
BBK Cold Air Induction
tannerc91gt
This last 25% is foreign territory at this point
2,977
234
Indiana
Nitrous will be fine with your setup. Autolite 23's is what I run gapped to 35 thou. (stock is 25s at 55 thou)
any plug that is 1-2 heat ranges colder will work (Copper core)
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,252
204
South Jersey
That identical setup minus the 331 bottom end (car had a stock bottom) was good for 11.1's w/ a c4 and 3.73's. Should run great for you. Definatly 2 heat ranges colder and .032 should be good on the plug gap
