need quick help, which way does the axle bearing go on?
Probably a stupid question, I know, but its not something I wanna do twice and I didn't disassemble the rear end myself, so I never seen it come out. The axle bearings can go in two ways, looking at the bearing it is more square on one side than the other side which is more rounded. Would I be right in assuming the more square side without writing goes in closest to the carrier? Thanks
The rear axle outer bearings are straight roller bearings and should work fine either way. It may be better to put the rounded side in first so that it clears the corner of the seat in the axle tube.
If this is about the carrier bearing, same idea, bit it really should not matter. For some reason, I have not paid attention to this on the axles I have assembled, and they all work fine.
