need some advice
  • Thread starter Thread starter stang9150
  • Start date Start date Jan 27, 2009
stang9150
142
Jan 27, 2009
  • Jan 27, 2009
I have a 91 hatchback with a 331.The motor has afr 185 heads,fti custom cam,performer intake,bbk cold air kit ,stock mass air and stock injectors.The car dyno at 290 hp 335 ft lbs.The motor feels great on the street and mantains 300 ft lbs from 2700rpm up to 5200 where it all starts falling off.Iam using the stock maf and injectors due to wanting the car up and running i know i should be at least 30lbs injectors.What should i do about the intake i think that maybe a big bottle neck right now and why power falls off after 5000.The performer worked good on my mild 302 so on it went to get running.Any suggestions on what intake to run?The car has a tko-600 and 373 gears also.thanks for any input.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Jan 27, 2009
  • Jan 27, 2009
you need injectors first. Then worry about the intake.
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,134
2,759
224
Vass, NC
Jan 27, 2009
  • Jan 27, 2009
If you have an FTI cam, then call ed. The perfect intake will correspond to the specs on his cam. He can tell you what you should get.
Go with an MAF and injectors first.
Chris
dcurtis
688
Jan 27, 2009
  • Jan 27, 2009
What about throttle body and egr Sizes.
stang9150
142
Jan 28, 2009
  • Jan 28, 2009
The tb is 76mm and the maf is a stocker for right now.I cant seem to get ahold of ED,at the moment it was acting like his email address was no good.thanks for the input
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
N
Having some drivetrain issues, need some advice...
  • Nicktheqwik
  • Nov 25, 2021
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 28, 2021
Monkeybutt2000
M
F
Advice needed for Foxbody build
  • FireGT1017
  • Jul 30, 2020
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 5, 2020
revhead347
Progress Thread diving back into my 87 lx after a 10 year hiatus need some advice
  • 87fox72mach
  • Apr 30, 2020
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2020
87fox72mach
