I've got a 94 gt, 137,000 miles, AODE, mods in sig....
Can you safely run cylinder heads with 2.02 intake/1.60 exhaust valves on a stock bottom end 5.0?
Do you/should you run 93 octane once you have done a H C I?
Will I have to buy new injectors if I do a H C I, or will the stock 19 lbs. be okay? If I need new injectors, not going to do forced induction, which ones would be good sufficant for the setup? What other mods, tranny, rear end etc., should be done to ensure longevity?
I am almost 100% sold on getting a bottom re-build kit from Federal Mogul. The kit is about $420, and includes pistons(forged), rings, mains, gaskets etc.
I want to do a H C I, but not sure which one to go with. I guess it is between Trick Flow's top end kit, and Holley's SysteMax top end kit...
I know the 94-95 GT's have idle problems when a cam is installed with higher inch lift than stock. I have also seen guys with stock cams make some pretty good numbers, but they don't get the "cam" sound from the exhaust.
Any help, input, suggestions are welcome and THANK YOU in advance.
....wow that pretty much says it all.
