Need some eec help what do I do.......
  • Thread starter Thread starter 89lxntch
  • Start date Start date Sep 13, 2008
89lxntch
  • Sep 13, 2008
I just installed my tweecer on the eec and was wondering if it needed to be mounted or could it just be stuffed in the pass. side cubby......I notice it had a grounding screw and metal tab on the plastic holder but with the tweecer on I cant get it back in the plastic holder........so do I leave it naked and throw it back in or do I try and modify the case to mount it back what do ya think
Fett
766
  • Sep 13, 2008
I remounted my PCM back where it belongs, drilled two small holes inside my glove box to run the USB cable and to mount the switch. Clean, you don't see anything unless you open the glove box, even then all you see is a USB cable and a switch knob.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Sep 13, 2008
  • Sep 13, 2008
i couldnt get my EEC back into the correct location, i just stuck it up there carefully and it doesnt move around at all and its fine.
i also keep my switch box and USB cable in the glove box. but i didnt drill holes like Fett did, i just simply routed the cables over the top of the back of the compartment.
vristang
4,933
101
124
Seattle
Sep 14, 2008
  • Sep 14, 2008
I busted the crap out of the stock white bracket and wedged the ecu into place.
I ran the usb under the dash, and along/under the center console.
The switch box cable is just long enough to reach the little storage arm rest.
The usb cable is still long enough to plug my laptop into in the passenger seat.
I move the tuner between 2 cars, so it needs to be easy to pull out.
89lxntch
  • Sep 14, 2008
Thanks I was hopeing I could just pit it back in there...I dont think I can mount it back in it position with the huge ac/heater box......Thanks again now on to the tuning portion of my build.....wish me luck
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
1991 GT cigarette lighter/port not working (horn is working)
  • MartinM
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
MartinM
M
I don know what im doing!
  • Sha_lala_pookie
  • May 5, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 11, 2025
Sha_lala_pookie
