Need some EFI help ASAP please.
  • Thread starter Thread starter 88 Fox GT
  • Start date Start date Aug 26, 2004
88 Fox GT
1,674
Iowa
Aug 26, 2004
  • Aug 26, 2004
I took out the fuel pump and wiring harness for the pump, but I am stuck. I modified it and removed the wires for the tail lights and un-needed stuff. So here's my problem. There is a brown/red wire running from the pump to the inertia switch, then a green/light green wire runs from that to a connector and another harness. I am at a loss right now. Where does this green/light green wire go to? What did you guys do to hook up the power to your fuel pump? What all am I going to need to get the fuel pump working on my '65? The fuel pump wiring is the last thing I need off the donor car and want to get rid of it ASAP. Thanks!
M
mustangracer
360
Southern California
Aug 26, 2004
  • Aug 26, 2004
Dunno the colors for a 94-95, but the fuel pump feed goes to the inertia switch and then to the fuel pump, the other lead from the fuel pump goes to ground. There should have been a short connector harness on the fuel sending unit that has the fuel pump and fuel sender feeds.
I think the stock wiring has a ground in the harness for the fuel pump and sender, but I think you can just run the grounds to the body.
88 Fox GT
1,674
Iowa
Aug 26, 2004
  • Aug 26, 2004
I know where I can hook up my ground wires. But, I'm talking power wire. Into the ignition or what?
F
Fostang
1,400
Stockton, Ca
Aug 26, 2004
  • Aug 26, 2004
Fuel pump-has positive and negative. Negative obviously simply grounded.
Positive comes from fuel pump relay.
Fuel pump relay has 5 wires hooked to it.
1- is the 12 volts constant
2-12volts out and on this wire there is a fuel pump monitor wire that runs to the eec.
3-turn on lead from eec low voltage.
4-ground.
88 Fox GT
1,674
Iowa
Aug 26, 2004
  • Aug 26, 2004
Where can I find the fuel pump relay?
F
Fostang
1,400
Stockton, Ca
Aug 26, 2004
  • Aug 26, 2004
under the drivers seat.
of and forgot to mention the inertia switch should be hooked to the line from the eec to the relay. On some cars it's the main 12 volts from the relay to the fuel pump.
F
Fostang
1,400
Stockton, Ca
Aug 26, 2004
  • Aug 26, 2004
relay is a green one.
88 Fox GT
1,674
Iowa
Aug 26, 2004
  • Aug 26, 2004
I looked under drivers seat when I heard it was under there before. No relays what-so-evern. Is there any way I can do it on my own without all the extra jumbo? The EFI swap is starting to get hecktic, I have alot of stuff to modify using a '94 engine.
F
Fostang
1,400
Stockton, Ca
Aug 26, 2004
  • Aug 26, 2004
yeah get yourself a relay and wire it like I stated above.
Oh thats right I think the relay is in the engine compartment in sn95's
88 Fox GT
1,674
Iowa
Aug 26, 2004
#10
  • Aug 26, 2004
  • #10
Where can I find the fuel pump relay that I need at a parts store or something? Any pics of one hooked up? My head is just spinning trying to figure out all the stuff I need to modify to make this engine work...ahhh!
F
Fostang
1,400
Stockton, Ca
Aug 26, 2004
#11
  • Aug 26, 2004
  • #11
first take a deep breath and relax, it's easy if I did my first efi swap at age 19 you can also.
Getting a wiring diagram will help you understand what all those wires are.
Yes you can get a relay from the parts store.
Sorry no pics.
88 Fox GT
1,674
Iowa
Aug 27, 2004
#12
  • Aug 27, 2004
  • #12
Yeah, I'm doing this swap at 16 years old. So far I'm doing ok, it's just the wiring and stuff that's got me in a bind as to what I'm gonna do. lol
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 27, 2004
#13
  • Aug 27, 2004
  • #13
OK, I have all the wiring diagrams, what did you steal the computer out of?
year make model and engie code?
P
PCH_Cruiser
69
Palmdale, CA
Aug 27, 2004
#14
  • Aug 27, 2004
  • #14
Any standard relay will work, it doesn't have to be from the donor car. Parts Express has Bosch relays for $2 each. If you've never wired your own relay, go to this website and scroll down to section 36. The computer supplies the turn on signal to the fuel pump. Get power from a good source like the fuse box.
CochinoFilipino
171
CA
Aug 27, 2004
#15
  • Aug 27, 2004
  • #15
You can always search and post in the 94/95 od 5.0 sections. I did a search on 'pump relay' and got this
http://forums.stangnet.com/showthread.php?t=478826&highlight=pump+relay
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
W
Need help! 1989 mustang
  • wickedzach487
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
