86HO5.0
SN95 Control arms will improve tire clearance, turning radius, handling and slightly improve bumpsteer.
245-255 tire width is about the max front tire size you can run on an 86, why not improve front geometry? The narrow K member with the SN95 spindles has caused issues on a couple different cars where obtaining acceptable camber wasn't possible (with CC Plates). This issue is why I ran SN arms instead of fox arms. Gained A LOT of tire clearance up front with the same size tire.
I edited a post above--DO NOT run 96-04 spindles on a Fox. Adding spacers will only make it worse.
