Ok, in short I am converting a 66 manual drum vehicle to front manual disc and rear manual drum. I did some searches, and came up with some conflicting and vague results.
The particular swap I am doing (scarebird) requires a 1967+ dual resevoir master cylinder for disc/drum manual brakes. I went to autozone, and they had reman. units for 30 bucks. The unit I got had 2 bowls of the same size. I thought the manual disc/drum units had a smaller bowl for the drum, and larger bowl for the discs? I went back to autozone and the guy kept pulling up the same number for the master cylinder. Is this correct/will it work? Is autozone incorrect? Are they trying to kill me?
Thanks in advance
Thanks in advance
