Need some help please
  • Thread starter Thread starter 89LXhelp
  • Start date Start date Sep 4, 2008
89LXhelp
Hawaii
Sep 4, 2008
  • Sep 4, 2008
Hello everyone,
I'll try to keep this as brief as possible. I purchased an 89 LX with about 120k on it about 2 weeks ago. I am in the military and so was the guy I purchased it from so I took his word for it when he told me he's never had any major problems with the car. The first week driving it everything was fine. But starting today I was driving back to the base and it started dying on the highway everytime I put the clutch in to shift.
Once I pulled the clutch out it would start and a few times it backfired. I've been outside for the last couple hours trying to figure out I replaced the distrubuter cap and plugs but I dunno really what else to do it could be all kinds of things. I'm in the military and cash is tight so I really hope it's not anything to expensive but are there any thoughts?
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Sep 4, 2008
  • Sep 4, 2008
I would do a tune up which you've already done some.
-cap,plugs,wires,rotor,fuel filter,oil change
I would check these few things and get back and post your finding (if any)
-check timing
-check TPS (throttle positioning sensor)
-check all vacuum lines and replace ones that are cracked
-clean out the IAC (idler air control valve)
-pull any codes
Does the car idle fine? If you give it a revv does the idle bounce around and then settle?
Fred
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2008
  • Sep 4, 2008
Most military bases stateside have an auto hobby shop. It is a great place to work on your car and sometimes you can get some help too.
A paperclip is all you need to dump the codes, so on the short list of cheap things to do, this is #1.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
HISSIN50
34
129
Sep 4, 2008
  • Sep 4, 2008
Be sure your VSS is connected.
85ragtop
BTW, I like dudes.
475
123
NC
Sep 4, 2008
  • Sep 4, 2008
Added "help" to the title for you.
D
davorstang
  • Apr 29, 2009
proooob
check neutral safety switch , or fuel cut off in the back by the trunk
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
