P pvtdiaz New Member Sep 26, 2009 11 0 2 Los Angeles Feb 23, 2010 #1 Feb 23, 2010 #1 i have a 1968 mustang with a 302cid engine and a c4 which is on its way out so i was wondering what do i need for an AOD transmission conversion like where can i buy the parts to every part i need to convert it any help would be appreciated
D D.Hearne New Member Sep 29, 2000 11,730 6 0 south louisiana Feb 23, 2010 #2 Feb 23, 2010 #2 Might want to consider an AODE or 4R70W, using this: Holley TPS kit p/n HLY-534-202 (Summit racing) Looks like an easier way to go.
NasaGT Founding Member Sep 19, 2002 1,993 2 49 Virginia Feb 24, 2010 #3 Feb 24, 2010 #3 All of the major Mustang vendors sell the parts for this swap, NPD, Mustangs Unlimited, Mustangs Plus,.... There also several good threads about this swap that detail what you need. Search for "AOD Swap"
tx65coupe Active Member Nov 29, 1999 1,551 1 37 Feb 25, 2010 #4 Feb 25, 2010 #4 I would go with a non electronically controlled AOD if your staying carbed. You could check with Modern Driveline, but I think they are primarily 5 speed conversions. I got my T5 stuff from them. http://www.moderndriveline.com/ Here are some links you might find helpful. http://restomod.us/AODSwapPage.htm http://www.mustangmonthly.com/howto/33598/index.html http://www.mustangandfords.com/howto/5280_automatic_overdrive_transmission_swap/index.html http://www.transmissioncenter.org/classic_mustang_to_aod_conversion.htm http://www.stangnet.com/mustang-forums/488700-aod-swap-part-list-questions.html
