Need some help with low oil light/CEL...
90mustangfan
93
So cal
Ok i about to buy a 89' mustang and I noticed that when I was driving the low oil light came on and at the same time the Check engine light came on too...I asked the owner and he said that when the low oil light comes on the Check Engine light will come on also? is this true? he said It just needs an oil change and or to add a QT or 2 of oil...I cant remember if when the low oil light comes on the CEL will too?????
That's not true, the two are unrelated. The low oil light should only come on if the oil level is low. The check engine issue, you'll need to pull the codes to figure out what the reason behind the light is.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Post the codes here in 5.0 Tech and we will try to help you fix them.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
