  • 1994 - 1995 Specific Tech
Need some help
  • Thread starter Thread starter govtmule
  • Start date Start date Aug 28, 2004
G
govtmule
95
  • Aug 28, 2004
I had just gotten of the interstate and came to a stop light and the car started to shake its a** off. I gave it a lil gas a figured it was a hiccup. Not the case, its shaking its a** off ang generally running poor. I poped the old hood and the plate behind my crank pully is not atatched and is just spinning. What is this plate? Is this the problem? How can i fix it? It makes me wanna cry to go start it up
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 28, 2004
  • Aug 28, 2004
Sounds like the balancer gave up. Do NOT run the engine any more than you have to with a broken balancer, or you will be rebuilding the bottom end. Stock replacement balancers are cheap, and as long as you're mostly stock they are fine.
Dave
G
govtmule
95
  • Aug 28, 2004
thanks alot gonna go pick a new one up, is this a hard install? it didnt look very hard
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 28, 2004
  • Aug 28, 2004
No, the stock balancer should be trivial (some of the aftermarket ones can be a real PITA). You'll just have to yank the serpentine belt, unbolt the crank pully, and remove the balancer bolt (pretty big bolt, like 7/8 or 15/16 if I remember correctly). The stock balancer should easily slide right off, and same with the install of the new one.
Dave
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
J
Fox 1986 V6 Fuel/Electrical Issues, crank, no start, turns over with starting fluid
  • JlChamberlain
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
gkomo
A
Emergency brake causing starting issue, need help.
  • Ace2203
  • Feb 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
Mustang5L5
