  • Mustang Sound & Shine All
need some help
  • Thread starter Thread starter Ford_Racing44
  • Start date Start date May 1, 2005
F
Ford_Racing44
17
  • May 1, 2005
i have a 98 mustang, and its got a stereo with a seperate single cd player underneith it, i want to replace the speakers, and possibly put in an amp. first of all, is there a factory amp? and if so, can i replace it with a bigger amp to avoid putting in a new cd player and amp and having to run new wires? the stereo now can't even push the stock speakers at half volume continuously without it getting louder and softer. also, what would be a good setup to get? im on a budget of about $800
N
nocaratall
132
May 1, 2005
  • May 1, 2005
you should swap the factory head unit and all speakers.
you can get a decent Alpine for $200 and four boston acoustics nx7 (5x7) and a four channel amp giving them 50 rms a piece. a buddy of mine has the same setup and sounds really good. surprisingly good bass for not having a sub also.
F
Ford_Racing44
17
  • May 3, 2005
so can you use the factory wiring or do u have to run new wires to the speakers? in other words, if the car has a factory amp, can u replace that so you dont have to run new wires?
D
DMDyne
43
Warren, Ohio
May 4, 2005
  • May 4, 2005
As long as you don't have a mach system or have any coroded wires, then you should be fine with the factory wiring.
89 GT Convertible Rear Speakers Quieter Than Front
  • JulianR
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 26, 2025
K
Need help with 99 cobra mach 460 audio
  • kevinatd18
  • Mar 16, 2024
2K
Mustang Sound & Shine All Mar 17, 2024
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
3K
Fox 5.0 Mustang Tech May 6, 2026
AeroCoupe
