need some help
hey guys, haven't been on the forum for a while but I'm still having the same starting problems. I still have to start the motor EVERYtime on ether, and a few days ago i went thru my IAC with carb cleaner and ear swabs, so i was wondering if anybody had any ideas?
What happens if you cycle the key a few times before attempting to start it? This will allow the pump to repeatedly prime before it cranks for the first time.
Codes?
Good luck.
I would search Jrichker's posts for his code dumping links.
If you have a grey TFI, I might make sure you have power to the appropriate terminal while cranking. See this diagram for more detail.
I might also put a noid light on an injector while cranking and see if it blinks at you.
I'm sure Jrichker or Tom would have much more precise input.
Good luck.
