so for a long while now, my car does not want to drop to an idle when i'm coming to a stop. for instance, if i'm pulling up to a stop sign or light or whatever, as soon as i push in the clutch, the car tries to stall; i have to hold the throttle slightly to keep it from dying, and when i'm finally at a complete stop, it will idle fine (unless i don't blip the throttle and it dies).
SO, i noticed the other day my o2 harness was ripped, so i got another one and replaced it. after that, i ran the codes on her. here's what i got:
KOEO:
67 - A/C on or neutral switch open/out of range
85 - canister purge circuit failure
KOER:
94 - thermactor air system inoperative bank 2 or fuel control circuit failure
44 - thermactor air system failure
MEMORY:
29 - insufficient input from VSS
91 - no exhaust gas oxygen switching detected bank 2
ok so as far as code 67, i have no A/C so i probably need a new neutral safety switch; mine has been a bit finicky, i have to have the clutch pedal absolutely mashed to the floor to start my car
code 85, i've pulled out all the smog stuff, and i don't have my purge solenoid hooked up. will not having the purge solenoid cause any problems other than smelling gas?
the KOER codes, i know what/where the thermactor valve is, but i don't know anything about the thermactor air system. if someone could enlighten me on whether these codes will cause a problem, please let me know.
memory code 29, i'm assuming i just need to replace my VSS. do you guys think this is the main culprit in my stalling issue?
memory code 91, i need to replace my o2's anyway, but seeing as both this code and the KOER code 94 both refer to bank 2, is there something else there i might check into?
thanks for any and all help!
here's my combo, by the way:
308, Ross forged slugs, cobra intake, Thumpers w/ 1.94/1.6s, Anderson n-412 cam, 65mm tb, proflow 75mm maf, 3.5" power pipe, 24# inj, 255lph fp, 1.6 rr's, kirban afpr, u/d pullies, no a/c or smog, taurus fan w/ DC control, KC clutch, pro 5.0, 4.10s, hedman L/Ts, 2.5" H pipe, spintech prostreets, alum d/s, MAC c/c plates, MSD 6al w/ blaster coil, Taylor ThunderVolt wires, 3G alt, full-length sfc, UPR uca's/lca's, tokico struts, strange 10-way shocks, maxspeed springs, HID 5000k
KOEO:
KOER:
MEMORY:
