I have a custom Schnieder cam that has been giving me some problems for the last month or so, i have been told that it will be lazy up top but make tons of torque. Also the cam is set up for a non HO firing order so i switched the plug wires but the injectors are still firing the HO firing order. i havent driven the car since i figured out that those cylinders are running lean.
INT EX INT EX
Here are the specs 544/.560 lift and 214/230 duration at .050'' (I dont have the cam sheet handy but thats waht i remember off the top of my head)
Now with those specs what kind of power should this cam make, the previous owner of the motor ran it with a 175 shot on it he also claimed that he revved the motor to 8k but i find that hard to believe with a hydraulic cam.
I am seriously thinking about swapping the cam and getting a set of Twisted Wedge full CNC 185cc heads putting my RPM 2 intake on it and getting rid of my blower because i am not sure about how the CR(9.75:1) will do once forced air enters the chambers. here is the current combo
R-block bored .060 over
Arias Flat top pistons
Carrillo rods
Bryant crankshaft
Schnieder Custom Cam
Twisted Wege heads with 1.7 RR
RPM II intake
42# injectors
255 lph in tank pump with an external pump stock lines/rails
Bassani 1 5/8'' to 13/4'' longtubes with 3'' X pipe to 2 1/2'' spintech pro streets
Lightning MAF, AFM Power Pipe.
I know its alot of info but any help/suggestions are appreciated
INT EX INT EX
Carrillo rods
Bryant crankshaft
RPM II intake
42# injectors
