Hey guys, i ordered some parts off Ebay, some already came in and some are on the way...
-I got TrickFlow R-series upper/lower intake manifolds
-A TrickFLow R-series 1" intake spacer
-Accufab 75mm t/b and egr spacer
-what are some good fuel injectors? BOSCH, FORD MOTORSPORT, ? etc.
& now i'm about to bid on some cylinder heads but can't decide between AFR 185cc or TrickFlow TrackHeat heads? ?
---would the TrickFlow heads go better w/ the TF manifolds or it doesn't matter, also, if i did get the TF heads, then would a TF camshaft work better than let's say a CompCam or CraneCam?
---I'm just confused about what i should do,if mixmatchimg parts is good/bad and that's why i wanted to ask you guys here at stangnet...
ONE more thing, as for the cam, there's so many to choose from, i want one that will make my rpm's jump up and down whening idling...go from say 800 to 1500rpm's then drop back down to 800, over and over again....sweet!!!
THANKS
Stan
THANKS
Stan
