Need spark plug advise
They look typical to me also. Possibly that #5 plug is not firing all of the time. Possibly it is interfering with #6 since they are companion cylinders which fire consecutively. I'd make sure your number 5 & 6 wire are separated on opposite ends of the wire loom and only run perpendicular to each other away from one another. Cylinders 1 & 3 are like this also in the firing order. If the wires are ohmed out and good, switch plug 6 with say 7 or 8 or either 1, 2, 3, 4 and then see what it looks like. If either of those plugs get dark, then proceed to swapping the injectors. This way, its less work and may solve the problem easier ... afterall, new injectors really shouldn't be loading up the cylinder. It could happen but likely your problem is in the ignition system. Post what you find!
