I have an '02 GT 5spd. Bought it with 20K miles, now has 65K on original clutch with MANY burnouts, launches, drag strip passes.
Over the past year, my clutch feel has been mushy and I'm getting a slight "tapping" sound when the clutch pedal is up sitting at idle in neutral. The tap goes away when you push in the clutch. I wanna do a clutch before it leaves me stranded!
I have a few questions...
1. Do I have a 6 or 8 bolt crank? What's better aluminum or steel flywheel?
2. What's the best clutch I should go with? (making about 300rwhp)
3. What is everything I need to do the swap that a kit doesn't come with? (I want to replace everything that wears while I'm in there.)
Thanks guys. You haven't let me down yet!
I'm also a painter for a high end body shop in NJ if anyone needs paint work done. Check my "classifieds" ad!
