Need these replacement parts! PICS INSIDE!
savegoodautonfg
1,085
Hey all,
I need these replacement parts. Please give me links to where i can get them if you can. I'd really appreciate it.
I need the metal retainer bracket thing that hold these in place.
The Main Part of the Side Skirts
The yellow is showing the metal retainer brackets i need.
Can i please have links to where i can buy these. preferrably 50resto.com
Thanks in advance,
Nick
i had to make one set for my first gt due to rust the lumber store sales a half by 1/8 aluminum plating for pretty cheap i just got one of those counter sinking drill bits a drimel and some bolts with a phillips head on them worked great if i can find one of them ill show u a pic
I found them all.
http://www.mustangsunlimited.com/Su...Body&subCategory=&Keywords=MU_BD&CatKey=74-01
The thing i can't understand it says:
Used to retain the original ground effects to the side of the body, 4 of lower ones are required (2 per side), plus 4 upper retainers (2 per side), & 2 rocker panel retainers (1 per side).
I understand the 1 rocket panel retainer for the bottom of the door.
But then for the lower and upper. I would think you would need more then 2 each side. Because it looks like if you look at my picture the yellow i have one is straight then the other dips down. Is'nt that two seperate pieces right there?
