Need to find some cheap parts!!!!!!
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Nothing big I wanted to know if there is any place to find a cheap serpentine belt. I didn't want to go pay $40 dollars for one from autozone or ford. Also I want to know where to get a short belt for when I go to the track. I don't know where or what size to get. Also I need to get a speedo gear. I have 3:73 with an AODE. What gear do I need and where to get it cheap.
BTW- I just bought and installed a 65 mm ford motorsports TB and I am ordering an art carr 9.5 inch 3000 stall converter with B&M hammer shifter with proform shift light. :banana:
I found this for the belt you want--
The belt you want to use is a Gates model belt: part # K060465
The belt measurement is 21mmx1195mm o.c.
when you run the belt, just run it from your crank pulley, to the alternator pulley, and you want your tensioner to ride underneath the belt. It will give you proper tension, and also spin your water pump in the proper"reverse" direction. There you have it, about 10-15 free ponies for about $18.00:cost of the belt
by stangbanger94
