need traction bad!!
5.slowmaroon
75
i have a 1990 mustang gt and i took it to the track and i ran a 14 7. i couldnt hook up at all and i spun all the way through first second and third. i couldnt get a good launch either. i have the 16 inch ponys on it. what i was thinking is to put the old 15 inch rims on the back and put 275 nitto triple 5r's or slicks. any suggestions?
From what i hear the Nittos don't hook very well...but that's just word of mouth.
What you need to think about is weight transfer....if your car is lowered, this can be a problem. You can get a good launch even on street tires if the nose is allowed to rise up and transfer weight onto the rear wheels...but when a car is lowered, particularly if it has a raked stance (lower in the front) you're going to have issues with weight transfer. If your suspension is stock (mainly as in control arms and shocks/struts) then you may wanna look into that as being your next mod. I'm running BFG drag radials and they hook ok but still spun hard off the line and a little in second for me...i couldn't get better than a low 1.9 60 foot which i've done on street tires a few times.
i got e303 cam 373 gears bbk intake bbk springs msd ignition and msd coil underdrive pulleys mac shortys flowtech offroad hpipe bassani dumps. i ran a couple 15;1's i missed third and ran a 16;2.....i just got my liscens and my very first run ever was a 14;9 but my best time and seems pretty constant was a 14;7 so far. im goin to union grove tomarrow.
the NIttos need to be headed up beyond belief to hook well IMO, I have the MT streets and they hook up hot or cold
He means "heated" up :nice: With those mods though you should be in the low 14, high 13s if it's tuned good, which if you're spinning through 2 gears, you should be. What RPM are you launching at? if try shifting a little early going into 2nd gear too, that'll keep you from spinning quite so bad till you do get slicks/drag radials on
In my humble opinion forget the Nittos and go straight to the M/T ET streets. I ran the Nittos and spun like crazy last weekend. 1/8 mile track but could only muster a 8.50 @85 MPH. 60 ft time was like 2.10. Terrible run. Theres at least a 1/2 second in the 1/8 that I can't get because of traction. I'm an old drag racer and haven't run drag radials at the track on my own car but I did run another guys car with the M/T's and they definitely hook better. I tried every launch method and PSI you can try and 8.5 spinning was the best I could do.
BTW I'm not knocking the Nittos because they are a great street tire but not good enough for the drag strip. If anyone has a different opinion PM me and I may be able to hook you up with a set (P245-50-r16)with about 10 passes on them. They look good and run good on the street.
Tom
come now dude. did you reall actually spin all the way through 2nd, and Third with those mods.:bs:
