don't expect the control arms to do anything for traction. I know this from experience on more than one fox.
the above poster is right, once you hit a certain power level, the ONLY thing on this planet that's gonna help you is running a full time drag radial. At that point, I hope you don't drive the car, as you'll be replacing them once a year or so if you do drive a lot.
the 4 lug axles are fine, but I'd upgrade to a 31 spline setup. If you don't, with that much power you'll brake eventually if you're running sticky tires.
be sure you have weight transfer too. If you're lowered, or your suspension is too tight, you'll spin all day no matter what.
Good adjustable struts on the front end can help towards dialing in some give when you need it. My bro is running only 237 at the wheels, but he's got a lowered h&r suspension, and still spins at the track even with et street tires.
