neutral safety switch HELP!
valley82
204
San Diega, Ca.
Where can I find a neutral safety switch wiring connector???
My tranny is a new T-5 and has two studs that I assume are designed to have some sort of push-on connectors, I have searched all of the stang vendors and come up empty???
Unless you get an original harness off a late model Mustang and splice it in, you need to make your own. I get fema;e bullet connectors from the parts store, trim the plastic lip off the end so it's flush with the metal cotact inside, crimp them on to the back up light wires and push them onto the T-5 switch posts. If you are trying to wire up the neutral safety, I'm pretty sure the switch on the other side of the T-5 for that works backwards and you cannot use it. Meaning for the curcuit to function in a classic stang, the switch is off when it should be on, and on when it should be off...
