Neutral Safety Switch Replacement
  • Thread starter Thread starter alext14
  • Start date Start date Mar 1, 2007
A
alext14
21
  • Mar 1, 2007
The neutral safety switch on my 65 V8 Automatic Mustang crapped out so I bought a new one:
http://www.mustangsplus.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=MPFMP&Product_Code=00091
Could some on please tell me how to access and replace the old switch. I'm not really even sure where the neutral safety switch is located.
Thanks
P
palerider94
573
  • Mar 1, 2007
Assuming it's a c4 - it is located on the trans linkage section. Harness unplugs at firewall. When re installing you need to make sure lined up correctly - there is a small hole that that you put bit/paper clip and use it to line up hole on stationary part of switch. Just can't remeber if hole suppose to line up in neutral or park. Somebody may chime in - should be in a chilton manual - I know it's in a shop manual - which is a good investment - check out ebay - best prices.
Iamdiffrnt
197
South of Detroit, MI
Mar 1, 2007
  • Mar 1, 2007
IIRC you will also have to drop the pan on the tranny to remove the shift arm. Not too hard, just take pics or make sure you remember how everything goes back together.
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Mar 1, 2007
  • Mar 1, 2007
I just did it yesterday, I did not have to drop the pan, but it does make it easier if you do lower the tranny. From what I remember, it has to be in park for it to line up if I remember correctly.
Iamdiffrnt
197
Mar 1, 2007
  • Mar 1, 2007
Ok, it's been awhile since I did mine...I stand corrected.
jadesville
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Mar 1, 2007
  • Mar 1, 2007
If it's not a factory trans am and you have to install a cable bracket, then sometimes you have to.
66HertzClone
428
Central New Jersey
Mar 1, 2007
  • Mar 1, 2007
Ready? straight from the factory manual
1 Remove the trans linkage rod from the tranmission downshift lever
2 Remove the transmission downshift outer lever retaining nut and the lever.
3 Remove the two retaining bolts
4 Disconnect the two electrical connections, then remove the switch.
5 Install new switch with the bolts
6 With the transmission manual lever in neutral, rotate the switch and install a #43 drill bit into the gauge pin hole. The bit should go in the switch 31/64 in order to make sure the adjustment is correctly made. I wrapped the drill with tape when I did mine, made it easy to know how far it was in.
7 Tighten the attaching bolts and remove the drill
8 Install outer downshift lever and attaching nut. Install the downshift linkage rod to the downshift lever. Note on some years the rod may be a cable.
9 Correctly attach the wires to the switch, red to red, blue to blue. Verify operation BEFORE you try and drive the car.
10 Crack open a cold beer.
A
alext14
21
  • Mar 1, 2007
Thanks a lot guys, I'll try it tonight when I get home.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 1, 2007
  • Mar 1, 2007
By the way, it's on the drivers side of the trans. and the adjustment can be very finicky.
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
  • JRC99
  • Apr 19, 2025
JRC99
J
J
Neutral Safety Switch Woes
  • jpm67
  • May 19, 2021
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2021
jpm67
J
Drivetrain T-5 Neutral Safety Switch Pin
  • ZephyrEFI
  • Jul 22, 2020
2K
Fox 5.0 Mustang Tech Jul 25, 2020
ZephyrEFI
