  • 1994 - 1995 Specific Tech
Never heard pinging so I tried something, check it out.
  • Thread starter Thread starter 95Vert
  • Start date Start date Feb 8, 2007
First Prev 2 of 2
blksn955.o
3,263
st.louis mo 314
Feb 12, 2007
#21
  • Feb 12, 2007
  • #21
Nice how they have there timing in so soon compared to our eec.
Those look like totals and I would guess that the total assumes 10* base still right .
IF that is total with 10* base (meaning that the total number given is also with the base timing not an adder). Then he would still be some 14* higher and that WOT area saw 30* at 5-6k so he would be at 44*...I just dont see how he wouldnt be pinging with that WOT in 3rd, 4th, or 5th gear .
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 12, 2007
#22
  • Feb 12, 2007
  • #22
95Vert said:
Thanks for that link but I have NO idea how to read it. lol
So there was no concensus on how many degrees are added for TT right? I had also heard about the TT working best between 34-36*.
Well Nacho
In a nutshell the table tells you max load (wot) would be the top row
and
You can see the various rpm's there as well
Again ... this is WOT so it has nothing to do with idle setting
Looks like you should have around 27 degrees at WOT with a
dizzy setting at the factory setting of 10
Now say you set the dizzy at 16
then
You would add the value that is greater than 10 ... or 6 more
for
A total spark advance of 27 + 6
Grady
95Vert
1,785
North Mexico (deep south Texas)
Feb 12, 2007
#23
  • Feb 12, 2007
  • #23
So that would be perfect at 33*. Awesome. Thanks Grady.
95Vert
1,785
Feb 12, 2007
#24
  • Feb 12, 2007
  • #24
This crap can get a lil confusing. lol
blksn955.o
3,263
st.louis mo 314
Feb 12, 2007
#25
  • Feb 12, 2007
  • #25
Look at the bottom of the page though Grady it has a WOT value that I am guessing is the above .75 load in the bigger table. That WOT value hits just over 30 at 5k and is 26.7 up to that so the higher rpm's at WOT would be well into the 40's with the extreme timing he had at first.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 12, 2007
#26
  • Feb 12, 2007
  • #26
Well Greg
Again I'm not all that familiar with the Fox stuff
but
If I'm reading that Spark Table correctly
I see it along these lines
Load along the left side
and
RPM along the top
The smallest load appears to be along the bottom
and
The greatest RPM I see is 4K
Where do you see any representation of 5K values
It looks to me from a WOT perspective ..............
All the advance is basically in by 2500
and
remains the same to red line
As always ... don't wanna mislead anyone
so
If I've hosed up ... someone fix my mess up here
Wait ... Wait ... Wait
I see the additional data apart from the Spark Table
Is that data based solely upon RPM and RPM alone
if so
How different and bizarre is that
I mean ... does that over ride the top row of the table
cause
If it does ... its values are less than the original table
Ya'll don't follow me
I'm Smooth as a Goose ... Lost
Grady
HISSIN50
34
129
Feb 13, 2007
#27
  • Feb 13, 2007
  • #27
Hey guys,
I didnt mean to toss some info out and run off. I have some info on the other puter regarding the comparison of curves from when I played with the 94's ignition. Unfortunately I dont have access to the other stuff right now.
You can see why I struggle to keep the fox stuff separate from the Alpha-4 (or whatever you call the family of 94-95) processors. The fox really segregates WOT from non-WOT. Once you hit 2.71 TPS volts above the ratcheted TPS baseline, that's WOT as far as the puter cares (this generally occurs at ~3.71 TPS volts). And at WOT, the puter switches gears and goes to look-up tables rather than the touchier-feelier [adaptive strategy] crap that the Alpha-4 computers use. The fox method can lead to nice richness, rather than the more adaptable Alpha-4 WOT A/F trim, which I have the feeling has a leaner commanded-value.
If anyone is trying to piece this together, here's some Air fuel ratio stuff for the A9L, in case it's a lot different than the typical Alpha-4 puter WOT trim (I haven't a clue about the latter). I thought seeing both might allow someone to see why the fox method works and the Alpha-4 doesnt.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 13, 2007
#28
  • Feb 13, 2007
  • #28
Well JT
I was kinda sorta taken back by the difference between the two
family's of pcm's
I was attempting to help Nacho and I'm afraid I may have
added to the confusion or just done a really fine job of
mudding up the water here
I have been thinking about how that Fox stuff might work
It then came to me ... I've now seen this little surprising issue
as an opportunity to help some relate to just one advantage of being
able to data log
I can't tell you how many peeps have asked me Q's like ............
What do you do with the data
or
How can all that data help me
Here is a simple little example
Even though we don't deal with Fox stuff
and
Our pcm doesn't work like that
Still ... follow me for a second and see how you could use the data
to teach yourself the way a Fox works as far as spark values
between those two tables JT so kindly posted up for us all.
If you look at the spark table's top row it seems similar to
our spark table ... but ... as Greg pointed out ... there is that
other data at the very end and unlike that basic table ...
it provides rpm's up to 6K
If you look at the two ... it would seem the basic table gives
< values at 3K
but
The other data give > values at 4K to redline
With datalogging ... you put the dizzy at factory setting
and
do a baseline run to see the actual values.
You then work with the one of two options only ... make
another duplicate test pass ... you then got hard data
to show how your value adjustments effected the spark
curve.
Of course ... tons of info on Fox stuff is available
but
On some things ... like drivability issues ...
You can see several things might be helpful to fix a particular
issue you are trying to improve on
AND
You will not always be able to just copy what someone did
to achieve success with an issue you are currently working
on ... EVEN THOUGH ... the two of you may have very similar
combos
So ... Can you see the method to the madness now
In its most basic simple steps:
1) You pick the two or three suspected values
2) You get a baseline datalog
3) You change one value only
4) You do a duplicate pass of the baseline pass
5) You compare baseline data to changed data
Again ... Hope I did not hinder more than help
Grady
95Vert
1,785
Feb 15, 2007
#29
  • Feb 15, 2007
  • #29
Thanks a lot Grady and JT. This really helps to get a better idea of why I'm having driveability issues. Yesterday I was extremely fed up with my car. Some stupid things about everyday driving is driving me up the wall. stutters, missing, surging idle, exhaust low popping are just a few. i thought of just selling my car and getting a 98 cobra. I would just get the basic bolt ons and be running the same times I'm running with this one and won't have any driveability issues since I wouldn't mess with the cam or heads or anything. I don't know, that may seem easier than all this crap.
HISSIN50
34
129
Feb 15, 2007
#30
  • Feb 15, 2007
  • #30
Ha ha, you got the fox III surging idle. J/K.
Seriously, the surging is super common. Since you are doing the fox processor, I might shoot Jason (VRIstang) a PM. He's kinda like Stangnet's Fox III version of Mr Grady (he was the one who led the way to get the fox guys a tuning sub-forum).
Jason knows the ins and outs of the A9 processors (408 with a TwEECer) and might have some suggestions.
Just another option and great guy to ask.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 15, 2007
#31
  • Feb 15, 2007
  • #31
Nacho my friend
I would hope you and all the other members on this board by now
have seen I do try and help everybody in our little community.
I also strive to not put anybody down or anything like that.
Now having said that
and
Since you have expressed your drivibality issues here
I'm gonna point out something
and
Its not directed at you Nacho
and
It's not some childish attempt on my part to say ... "I told you so"
You did the All Mighty A9L Fox pcm retro fit swap in your 94-95 Stang
You are NOT supposed to have these issues
You ARE supposed to have nothing but benefits
You ARE supposed to have left ........
ALL that finicky 94-95 pcm stuff behind with the swap
I think this is an observation that goes to show
You can't ALWAYS ... Believe everything "They" say
Yes ... some have have had good results with the swap
but
Not Everybody ... which it usually seems to be presented as
I do so wish this had worked out better for you
Nacho ... I know you are frustrated
and
I know many here are willing to help
Talk to us ... maybe we can find something
Grady
Prince95GT
335
Canada
Feb 16, 2007
#32
  • Feb 16, 2007
  • #32
95Vert said:
I know^ That's what's so weird. I made sure it had load, was doing 40mph in 5th, then floored it and nothing.
Try doing at higher revs, go 40mph and floor in 3rd, I don't think you will ping unless your at high rpm, my car on a sh1tty day wont ping til over 4500rpm, I dont think my car would ping in 5th if I was going 130 and floored it
I
igotyofire
774
Southern California
Feb 18, 2007
#33
  • Feb 18, 2007
  • #33
my friend says disconnecting the EGR should make a car ping which is why he doesn't understand why people get rid of the egr
T
tjh566
608
Northern Va
Feb 18, 2007
#34
  • Feb 18, 2007
  • #34
if you disable it in the Computer all will be fine, but disconnecting it without a tune will cause issues.
HISSIN50
34
129
Feb 18, 2007
#35
  • Feb 18, 2007
  • #35
On an A9* computer, if you set an EGR code but keep the EGR position sensor capable, the computer is programmed to realize the EGR has an issue and shut off its function.
95Vert
1,785
Feb 19, 2007
#36
  • Feb 19, 2007
  • #36
Well Grady, you're right. I mean, I feel like I'm going to have to get a chip now. How many times do I have to clean my iac, maf, act, and set my tps? I have done it so many times and the car runs fine and idles fine, but every now and then, the idle starts to surge and it aggravates the hell out of me. I hear some exhaust popping. Nothing loud nor does it make the car miss, but it's doing it for a reason, and I can't seem to find out why. I have this week off so I'll be messing with the timing, iac position, maf, and changing out plugs. I hope something will do it. The weird part is that it 'drives' fine, as in it doesn't bog when in high gear and low mph. I hope it's just something I'm missing cause it wasn't doing it before.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 19, 2007
#37
  • Feb 19, 2007
  • #37
You know ... sometimes it can be the smallest things that can cause
drivability issues.
I can say for certain ..............
The smallest exhaust leak can ... maybe not always ...
suck in additional air that throws off the O2's reading
Over the years, I've seen peeps change out parts, make all kinds
of pcm value changes, and such, to try and fix an unstable Closed
Loop portion of the tune.
They later reported they found:
Vacuum Leak
Electrical Connection
Unmetered Air Issue
Exhaust Leak
or other simple but over looked issues
Make sure you got everything along those lines like it should be
Thats where I'd start to make some headway Nacho
Grady
95Vert
1,785
Feb 22, 2007
#38
  • Feb 22, 2007
  • #38
Thanks a lot. I didn't drive the car for 4 days(out of town) and have been driving since I got back(Tuesday) and it's been doing good. I looked at most of what you listed and I can't find anything. I guess I'm just being very picky. I should just get used to the occasional surge, which is what really gets to me, and just enjoy the ride. I keep romping on it just to make sure I'm not losing power and I don't feel it.
First Prev 2 of 2
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
