Check out how this guy did his suspension. Cool idea. How safe is this?
Not bad, but I think if I went to all that trouble, I'd want to use tubular control arms in place of the stock stamped ones.......
Judging by the cowl it looks like a 71-73 Mustang.is this on a maverick or something? it's definitely not a mustang, well maybe a big body but it still doesn't look quite right. ...
with the crossmember boxed in and the support bars there it looks pretty solid.
not much different than what racers did in the past. i agree though i would at least box the control arms, though i would also change the geometry of the upper arm for a better camber curve.
I gave-up on Mustangs after 1970 but I thought that in 71 Ford began using GM p/s units, a/c units and Rochester carbs. Read that Henry gave-up trying to beat them and put out the order to just follow their lead and use any part they could supply at a lower cost.Judging by the cowl it looks like a 71-73 Mustang.
I know the truth hurts, but after Ford quit racing, they didn't do a whole hell of a lot. Oh, wait, they built the PINTO. And Maverick. Sorry for the oversight.
It may be the angle of the photograph but it appears to me that the upper ball joint is higher than the mounting point at the frame. Isn't that what you want? You know, to pull the top of the tire in faster (shorter radius moving from the horizontal plain to the vertical plainand all that stuff) than the bottom control arm thereby giving you a camber gain?
But I'm probably wrong. Right?
What's funny is I didn't even see his post. Somehow, subconsciously, something was telling me it was irrelevant and I should skip it.Dude, have a beer, chill out or something. Did ford screw you over a pinto once upon a time? Or are you trying to pick a fight? Let it go already.
Current bid with 18 hours remaining: $152.501971 72 MUSTANG FASTBACK MACH 1 BOSS 351 CLONE RACE CAR PROJECT.4 SPEED CAR STILL HAS CLUTCH PEDAL. NO MOTOR/TRANNY. THIS IS AN ULTRA SOLID BODY ULTRA STRAIGHT. GREAT FRAMEWORK, FULL FRAME CUSTOM FRAME ALL PROFESSIONALLY DONE, HAS FRAME CONECTORS UNDERNEATH, EVERYTHING IS ATTACHED AND CAR IS ULTRA RIGID. FULLY ADJUSTABLE CUSTOM COIL OVER FRONT SUSPENSION WITH MODIFIED FACTORY CONTROL ARMS. DISC BRAKES. AWESOME CUSTOM ROLLCAGE ALL TIED TOGETHER TO THE FRAME. CAR IS SET UP FOR WIDE TIRES AND HAS OLD SCHOOL FENDER FLAIRS CUSTOM MOLDED IN, AND CUSTOM SETUP FOR RETRACTABLE ANTENNA. DECKLID IS DRILLED FOR REAR SPOILER BUT I DONT HAVE THE SPOILER. COMES WITH NICE RAM AIR NASA HOOD AND 2 VERY GOOD FRONT FENDERS AND A HARD TO FIND EARLY COATED FRONT BUMPER. CAR STILL HAS WIRING INTACT AND FACTORY INSTRUMENTS IN DASH SO EASY TO PUT THIS ONE ON THE STREET.HAS FANCY RACING FUEL PUMP SETUP IN TRUNK AS SEEN IN PHOTOS.ALL GLASS IS GOOD BUT NO WINDSHIELD. I HAVE MANY MORE PARTS THAT GO WITH IT INCLUDING THE BACK FASTBACK GLASS, TAILIGHTS, DASH PANEL AND MUCH MUCH MORE. LET THE PICTURES DO THE TALKING AND ASK ALL QUESTIONS BEFORE BIDDING. SOLD AS IS COMES WITH BILL OF SALE. ALL NEW OR ZERO FEEDBACK EBAYERS CONTACT ME FIRST BEFORE BIDDING...
